How can I substract the strings, including column names, I need from one cell?
The data that I have is like the following:
I would like to substract the information within the brackets, so I get the following result:
Can anyone help me how I can achieve this within my workbench?
geomancer
Forum|alt.badge.img+51
  • April 7, 2023
Update: You don't even need to add the HTML tags, using the HTMLExtractor on the original data is enough!
Without_HTML_tagsOriginal answer: One very quick way: enclose the value of REMARK in HTML tags, and use HTMLExtractor.
HTML_tags
  • April 7, 2023
Perfect! Very easy like that :-)
Thank you.
hkingsbury
Forum|alt.badge.img+55
  • April 10, 2023
HTML_tags
Thats a great solution, I was thinking StringSearchers with some Regex but this is much cleaner!
