How can I style a line based on the status of an area polygon it exists in?
  • Dec 7, 2017 10:41 PM UTC
  • 61 views
I have a built and design areas which have lines inside them, and would like to style the lines based on the status of the area it exists in.
i.e:
Area - Built = Blue line
Area - Design = Red line
danilo_fme
Forum|alt.badge.img+58
  • Dec 8, 2017 2:29 AM UTC
Hi @anthonydahya,
My suggestion:
1) Use the transformer LineOnAreaOverlayer and select the option Generate a List on Output Line.
2) On Output Port Line ( LineOnAreaOverlayer ) connect the TestFilter and filter by List according the attribute type from Polygons:
  • Built
  • Design
3) Add two transformers FeatureColorSetter on the Output Ports from TestFilter:
Thanks,
Danilo
Thank you I will give that a go, much appreciated :) @danilo_fme
danilo_fme
  • Dec 8, 2017 2:41 AM UTC
@anthonydahya
you are welcome :)
Thanks,
Danilo
For some reason my fmw file is now empty, will re do it and send you a copy of it :)
