The data conversion from the oracle database to dgn works fine. I see in Microstation that the coordinates are identical with the counterparts in the Oracle database. However, Microstation doesn't seem to know that it has a coordinate system. It says <coordinate system not set>.
In processes 'downstream' requires that the dgn files have a coordinate system for further usage. This is now a manual step, that we want to avoid. Is someone familiair with this and knows how we can setup FME to write the coordinate information?
