How can I set up a calculation to ignore values equal to 0 when calculating the mean?
  • May 5, 2023
  • 48 views
emerson_styles
Forum|alt.badge.img+3
I have a shapefile with numerous columns that I need to calculate a mean for on a row by row basis. Within the data there are a lot of values equal to 0 that are skewing the mean - how can I set up a calculation in the ExpressionEvaluator to remove the 0's from my calculation?
Best answer by dustin
Nulls would not be evaluated in that situation, so I would use a NullAttributeMapper prior to the ExpressionEvalutor setting all 0's to <null>. Then after your ExpressionEvaluator, use another NullAttributeMapper to set <null> back to 0's.image
dustin
Forum|alt.badge.img+31
  • May 5, 2023
