How can I set the coordinate system in the streaming service? Setting the coordinate system on the shapefile writer seems to have no effect. Any solutions?
  • May 3, 2022 3:57 PM UTC
  • 84 views
johnglick
Forum|alt.badge.img+7
When I run this workspace locally, it puts out a .prj file and all is well. The issue only occurs on fme server. there is no prj in the zipped download.
chrisatsafe
Hi @johnglick​ ,
What version of FME Desktop/Server are you using? Are you seeing the same issue if you register the job with the data download service instead?
johnglick
  • May 6, 2022 1:05 PM UTC
Hi @johnglick​ ,
The same issue occurs with the download service. I am on 2021.0.0.1 desktop and server. [cid:image001.png@01D86128.6D95A760] [cid:image002.png@01D86128.6D95A760] John Glick Cochranville Ag Service 610-869-9640 ext 200
chrisatsafe
Awesome, thanks for the info @johnglick​. I've escalated this post to a case so our support team can take a closer look as this is definitely not the intended behaviour. You should be receiving an email shortly.
Thanks again for posting this!
