How can I remove choices from the coordinate system gallery
I would like to remove some choices from the standard coordinate system gallery so my users don't confuse them with some similar custom choices that will be added via the MyCoordSysDefs.fme file. How do I do that?
try modifying the file <FME_HOME>\\coordsys.db using Notepad started as a local administrator.
I highly recommend making a backup first...
David
  • June 23, 2015
Thanks David, this worked for me.
