How can i remove an element from a list
  • Jan 5, 2017 10:56 AM UTC
  • 7 replies
  • 1319 views
bradr
Forum|alt.badge.img+9
I have a list and with ListSearcher i found that element with id {_list_index} needs to be removed completely from the list. How can i achieve this.
  • Jan 5, 2017 11:22 AM UTC
Hi @bradr, the ListElementFilter from the FME Hub might help you to keep or remove elements that match a specific condition.
bruceharold
Forum|alt.badge.img+19
  • Jan 5, 2017 2:54 PM UTC
This is why lists should be JSON structures... :-)
erik_jan
Forum|alt.badge.img+26
  • Jan 5, 2017 2:56 PM UTC
This calls for a ListElementRemover.
Post the idea, I would suggest.
jdh
Forum|alt.badge.img+41
  • Jan 5, 2017 3:28 PM UTC
I have exactly that custom transformer. Unfortunately I'm not allowed to post CT developed on company time, but it's a fairly straight forward PythonCaller. Get the list name, get the index, loop though the list (starting at i) replacing the attribute of list{i} with list{i+1}, remove list{-1}. The only "gotcha" is the behaviour of complex lists. Do you remove only the subcomponent, without reindexing, or do you remove all the related lists for that index, and reindex all of them.
bradr
  • Jan 5, 2017 3:46 PM UTC
Tanks @takashi, the ListElementFilter does the job!
bradr
  • Jan 5, 2017 3:55 PM UTC
done, https://knowledge.safe.com/idea/38197/listelementremover.html
aquee
Forum|alt.badge.img+3
  • Jun 25, 2025 6:00 AM UTC
Just noting that I had this same issue and a completely-vanilla solution (@2021.2.6.0) is to ListExploder the list, do some simple Testing/Filtering, then ListBuilder the elements (minus the ones you removed) back into a list.
