How can I map these properties as attributes within the created feature geometry?
  • Jun 1, 2023 5:24 AM UTC
  • 7 replies
  • 80 views
abdullah83
Forum|alt.badge.img+5
I am currently converting IFC format to Shapefile. So far, I have been successful in importing only the geometric objects. Due to the fact that most properties in the IFC are in separate classes, when they are brought into FME, they remain in their own feature types. How can I map these properties as attributes within the created feature geometry?
geomancer
Forum|alt.badge.img+71
  • Jun 1, 2023 12:38 PM UTC
I assume the geometric objects will have some unique ID attribute included, and this ID also appears as an attribute in the other feature types. Then you can join the attributes to the geometries using a FeatureJoiner or a FeatureMerger.
abdullah83
  • Jun 1, 2023 1:10 PM UTC
tqvm sir. i will try ... i also have one more question .. what is different​ attribut in table and attribut on freature information. how to manage attribute on feature information (querry) from any transformer?
geomancer
  • Jun 1, 2023 1:22 PM UTC
Something like this:
FeatureJoiner
abdullah83
  • Jun 1, 2023 2:59 PM UTC
FeatureJoiner
sir i mean is just like this..
pic apic b
The object with geometry is found in the ifcpipesegment, and the attribute that I want to connect is located in the ifcpropertyset (green circle). Both ifcpipesegment and ifcpropertyset are connected by an attribute in the red circle.
please help me sir.
abdullah83
  • Jun 1, 2023 3:00 PM UTC
pic apic b
please help me sir.
pic A is information for ifcpipesegment and pic B is information for ifcpropertset
geomancer
  • Jun 1, 2023 4:17 PM UTC
One way is to use a ListExploder to create a feature for each item in the list.
Then you can use a FeatureJoiner to join on "ifc_property_set" = "ifc_unique_id". You can do this for all the other feature sets as well.
In the end you will have to recombine the features, this can be done with an Aggregator.
I created a mockup workspace.
IFCLooking at PIC B I think maybe you can use attribute "ifc_unique_id" instead of "ifc_instance_name".
In PIC A the same value is in "ifc_property_set{1}". This is part of a list. So it makes me wonder what all other "ifc_property_set{}" values mean. Do they represent links to other feature sets?
Good luck!
abdullah83
  • Jun 1, 2023 10:14 PM UTC
Good luck!
tqvm sir for the example.. yap this is what i mean... i will try for my project , i learn bit by bit... soon the result i will post here for other...
