How can I find circular lines
  • Nov 17, 2017 6:39 PM UTC
  • 195 views
Does anyone know how I can find lines that form a circular loop with the same endpoints. I can find lines with the same endpoints by calculating the distance between the endpoints, but I am interested in determining if it forms a loop. I would like to process these in a different way. Thanks you for any ideas.
Best answer by linasvebeliunas
Thank you all. This is exactly what I was looking for.
jdh
Forum|alt.badge.img+41
  • Nov 17, 2017 7:03 PM UTC
There is a loopFilter custom transformer that does this.
erik_jan
Forum|alt.badge.img+26
  • Nov 17, 2017 7:11 PM UTC
Or you can use a Tester transformer to test if the coordinates of the start point are the same as the coordinates of the end point:
  • Nov 18, 2017 1:10 PM UTC
Hi @linasvebeliunas, the ClosedCurveFilter transformer might help you.
