How can i create and compare rasters from MIF/TAB files?
  • Sep 14, 2018 7:13 AM UTC
  • 0 replies
  • 65 views
Using infoworks ICM we have run 2d simulations on a flooding scheme. We have run a baseline series and two solution scenarios however due to the solution involving a water basin, the ground model has been altered and therefore the mesh is not identical to the baseline.
I previously created a tool which takes the baseline 2d results for each mesh triangle and compares to the flood depth to the solution 2d results but this tool only functions correctly when the mesh tables are identical. Therefore we believe that the next best way to do a comparison with two different mesh tables would be to create a raster for each and calculate the following (baseline depth raster - solution depth raster) in order to gauge the solution performance. However being new to the software I am struggling to work out how to create the rasters and furthermore, how to compare them. Any tips?
FYI - The current tool uses max mif files exported from the simulations in ICM
Cheers
