How can I create a point between two points if these two points are closer together than X? then delete the two original points, thus generalizing.
  • Mar 15, 2016 8:33 AM UTC
  • 5 replies
  • 63 views
fmelizard
Forum|alt.badge.img+22
  • Mar 15, 2016 8:59 AM UTC
Hi
You can use a NeighborFinder to find points closer than a specified distance, then a VertexCreator to draw a line between the point pairs. Then use a CenterPointReplacer to replace the line with the point in the middle and finally a Matcher to get rid of duplicate geometries (necessary because the NeighborFinder in "Candidates only"-mode will return one feature per point, not per pair). It could look like something this:
David
Forum|alt.badge.img+63
Just wondering out loud here: doesn't one of the generalization algorithms in the Generalizer do this?
  • Mar 15, 2016 10:04 AM UTC
Feel free to test ;-) I did have a look, but the Generalizer does not seem to consider more than one feature at a time.
erik_jan
Forum|alt.badge.img+26
  • Mar 15, 2016 2:06 PM UTC
You can use the NeighborhoodAggregator to create aggregate features and then replace the aggregate by a point using the CenterPointReplacer.
mark2atsafe
Forum|alt.badge.img+59
I thought that too, but I can't find it. Without that I think David's solution is probably the best
