How can I convert DWG with multiple views to MicroStation file?
  • Jan 6, 2021 5:53 AM UTC
  • 46 views
i tried to convert AutoCAD file with multiple views to MicroStation file using FME but the output file came with only one view ( which is model view)
my question is can i convert this file and the output come with all view ?
caracadrian
Forum|alt.badge.img+23
  • Jan 6, 2021 7:29 AM UTC
You have to configure your dwg reader to read Layouts (Paper Space) then figure out how to write the equivalent of Acad Layouts in Microstation (I think they are called views).dwg paper space
How can i reach DWG/DXF parameters in AutoCAD?
caracadrian
  • Jan 6, 2021 10:29 PM UTC
Select your dwg reader and press the red (magenta maybe) cogwheel database icon on top of it. The ​red one that is shown only when you select it, not the transparent one on the right. And a window similar to the one above opens.
Thank you .
