How can I convert a polygon, assuming a whole county into 100m bins?
  • August 4, 2017
  • 57 views
danilo_fme
Forum|alt.badge.img+57
  • August 4, 2017
Hi @tiki13457, could you share your workspace or your source data?
Do you have lines and want to convert polygons?
erik_jan
Forum|alt.badge.img+26
  • August 4, 2017
Have a look at the 2DGridAccumulator transformer.
That seems to fit your description.
  • August 5, 2017
If your requirement is to split a polygon into 100m x 100m square tiles, the Tiler transformer might help you.
