How can I cast a string to datetime for MS SQL?
  • July 26, 2017
  • 7 replies
  • 186 views
In my workspace I'm inserting through a FeatureWriter into MS SQL Table and I'm trying to cast a string to a datetime, but it doesn't seem to work.
This is the format that I'm reading: dd/mm/YYYY and I'm trying to parse the attribute column in FME as this:
@DateTimeParse(@Value(DATE_OF_BIRTH),%d/%m/%Y)
But I'm getting this error from the console:
2017-07-26 15:25:28| 162.1| 0.0|WARN |Table1_StudentUpdate_FeatureWriter_f2afd4cb_4a56_4aec_8f42_9e384693c40417: Failed to evaluate expression '@DateTimeParse(03/13/2010,%d/%m/%Y)'. Result is set to null.
Best answer by fmelizard
Hi @rrdlpl, it seems like the date in your log line is in the format MM/DD/YYYY. It's likely you're getting a null value in your output because the day and month are switched. Should the 13th month be an error, you can use the repair function of DateTimeParse.
fmelizard
Forum|alt.badge.img+22
  • July 26, 2017
erik_jan
Forum|alt.badge.img+26
  • July 26, 2017
Could it be that both the date string and the format string need to be enclosed in quotes?
@DateTimeParse('03/13/2010','%m/%d/%Y')
  • July 27, 2017
You're right. I switched them over, but now I'm getting this error:
MS SQL Server (JDBC) Writer: Error writing feature. Error: Attribute 'DATE_OF_BIRTH' does not contain a valid timestamp
lars_de_vries
Forum|alt.badge.img+10
Looking at this question on stackoverflow it seems that you should remove the slashes from the date.
  • July 27, 2017
Does the "DATE_OF_BIRTH" attribute contain a valid value? Check Workbench Menu: Writers > Redirect to FME Data Inspector then run the workspace, and see what value the attribute contain.
  • July 27, 2017
hi @takashi, this is the format of the incoming date 05/22/2000 and I need to convert it to 2000-05-22 00:00:00.000 so it can insert into the table
  • July 27, 2017
The @DateTimeParse function returns a date/time string with the Standard FME Date/Time Format (typically %Y%m%d, %Y%m%d%H%M%S), and it can be written directly into a date type field of a writer feature type in general.
Anyway, first of all, check what date/time string caused the error.
