how can ? change point cloud coordinate value in fme
  • Aug 15, 2018 11:27 AM UTC
  • 112 views
veyselakatay
hi everyone
? have polygons and point cloud. ? use Clipper
after that ? change point cloud z data
? need this math fonction (( all point cloud z value - polygon z value))
can you help me please
rsvp.
  • Aug 15, 2018 12:16 PM UTC
Hi @veyselakatay, supposing all vertices of the polygon have an idential z-value, a possible way is:
  1. Extract Z of the polygon (clipper) with the ElevationExtractor.
  2. Merge the Z to the point cloud (clipee) when clipping.
  3. Move the point cloud with the Offsetter (set -Z to the Z Offset parameter).
Hi @veyselakatay,
The PointCloudExpressionEvaluator may also be worth investigating in your case. You can set the Component to 'z', Data Type to 'preserve' and the expression to be '@Component(z) - <polygon z value>'
