How can blocks in DWG file not be broken down into their component parts after transformation
  • May 24, 2022 6:31 AM UTC
  • 7 replies
  • 186 views
arash_hokm
Forum|alt.badge.img+8
Hallo FME Community,
I have a DWG file with about 100 layers. I managed to reduce the layers to 20 layers with FME by merging layers. Blocks in my DWG result are broken up into their component parts and they aren't one block but several lines. does anyone know how blocks can remain as blocks after transformation.
Thanks in advance.
tomfriedl
Forum|alt.badge.img+14
  • May 24, 2022 7:13 AM UTC
not check Entity Options > Explode Blocks into Entities
write as "autocad_entity" > autocad_insert
arash_hokm
  • May 24, 2022 10:38 AM UTC
Hallo @tomfriedl​,
Thank you for reply.
mean you by ("autocad_entity" > autocad_insert) that I expose format attribute "autocad_entity" and give it that "autocad_insert"?
tomfriedl
  • May 24, 2022 11:11 AM UTC
Yes
arash_hokm
  • May 24, 2022 11:24 AM UTC
Yes
@tomfriedl​  I did the same. in this case I unfortunately get an empty DWG file. the layers are there but layers are empty.
tomfriedl
  • May 24, 2022 11:45 AM UTC
You have set autocad_block_name? The write have a "Template file" with defined block?
Block
arash_hokm
  • May 24, 2022 12:50 PM UTC
@tomfriedl​ my transformation is DWG to DWG. I merg only many layers in 3 layer during the tranformation.
I have such complicated DWG file.
DWG (1)before the transformation I got blocks and after the transformation I would get blocks as well.
DWG (2) but I get polyline.
DWG (3)can't blocks stay as a block, if I don't have a template?
tomfriedl
  • May 24, 2022 12:58 PM UTC
You have a template. It's your source-file. Don't explode blocks.
