Who tried failed login?
  • Jun 19, 2025 11:14 AM UTC
  • 143 views
laurensdelfland
Forum|alt.badge.img+11
We use Azure Entra ID (formerly known as Azure Active Directory) with FME Flow to login the application.
So now we have two methods:
1. user name and password
2. button "Sign in with Microsoft"
My colleagues often use the first method, which does not work for them.
I set up the system events to notify me when a login is failed. But now I would like to know who tried and failed to login. Is there a log that shows the username someone used to try to login? Does anyone know which logfile it is in?
ps it would be nice if I could hide the first login method. But that method is used by the admin-account. So I guess that is not an option.
Best answer by ebygomm
System Events should show you the username of the person who tried to login?
alexbiz
Forum|alt.badge.img+35
  • Jun 19, 2025 2:21 PM UTC
Here is an exemple of an automation event :
  "automation.id": "13806e84-dbf2-441a-ab05-5309ec4569c2",
  "systemEvent.description": "Triggered whenever a user failed to login to the web interface.",
  "source": "system-event",
  "time": "2025-06-19T16:14:04+02:00",
  "message": "Failed login by user wronguser due to insufficient credentials.",
  "event.id": "b42409a4-d811-42a4-a631-4c1cff54af94",
  "user": "wronguser",
  "automation.name": "Untitledsdf",
  "systemEvent.title": "Login Failed"
You can get the message as well as the user from that event, and use them as input for workspace parameters :
Or directly use them in your email action :
Forum|alt.badge.img+54
  • Jun 19, 2025 3:07 PM UTC
laurensdelfland
Thank you both (@ebygomm & @alexbiz) for the very useful responses!
I just tested some things and yes, the username does appear in the System Events!
Apparently I have users that just click the Log In-button, without even entering a username. An event is logged, but understandably without a username. I guess that sort of confused me and lead me to believe the username was not logged at all or maybe only in an obscure log somewhere.
