How add unique ID/Value to an Element
  • Jan 8, 2022 7:36 AM UTC
  • 127 views
chithramc
Participant
Forum|alt.badge.img+4
Hello friends,
Im a new user of FME.
I have a dgn file with hundreds of points with or without tags. i need to convert this dgn to shp with unique custom ids. Is it any procedure or transformers to do this in fme. I mean each point have unique id numbers
I tried with many videos and tutorials didn't solve my issue
thanks
Best answer by chithramc
Hello friends,
I solve the issue in this way
Reader > counter >Attribute Manager>writer
Reader = dgn and writer = shp
Counter = Change counter parameters
  1. count start (only numeric values)
  2. Output attribute name
Attribute = Attribute parameter Values
  1. parameter condition definition changed
  2. changed test condition and attribute value
Writer = Feature Type > user attributes > manual > typ change to char
for forum new attribute value creating
@chithramc​  If you want integer IDs you can use the Counter. UUIDGenerator will create, well, UUID's.
chithramc
Participant
  • Participant
  • Jan 11, 2022 8:14 AM UTC
Hello friends,
