Hi there. When I run workbench with the SchemaMapper transformer, I get an error stating that a .csv file cannot be opened for reading. The problem is, I did not choose that file. I chose a different file. Can anyone tell me how to change this parame
  • Sep 6, 2023 2:12 PM UTC
  • 32 views
paul.stanley
Participant
Forum|alt.badge.img+3
imageThe file with the error is not the one listed here, and I don't know where the translation is getting the parameter that has the error.
kailinatsafe
Forum|alt.badge.img+24
Hello @paul.stanley​, thank you for posting! Sorry to hear you're having issues selecting the proper CSV for schema mapping. Happy to try and reproduce the issue. If you're able to answer any of the following, that would be helpful:
  • What version and build of FME Workbench you're currently using? (Help > About FME Workbench)
  • Does purging the temporary files help resolve the issue (Tools > Purge Temporary Files)
  • Does it always error with the same CSV file or does it change?
It may also be helpful if you're able to share a logfile with the error captured. Thanks in advance, Kailin.
