Hi! Is it possible to convert a CGXML file into a shapefile with associated attributes directly with DataInterop ?
  • Aug 13, 2019 2:00 PM UTC
  • 72 views
I'd like to get the points and create the polygons and have the attributes from the CGXML file.
palhermans
Forum|alt.badge.img+11
  • Aug 14, 2019 10:23 AM UTC
I would say no - in the way there is no direct reader for CGXML. You can read XML files with Workbench and from there make a workbench for a transformation to ArcGIS formats. Encourage You to post a CGXML example.
