Hi I want to reproject some dwg files from CSRS.UTM-17 to CSRS.MTM-10. However, when I use this projection the results are not correct. Could you please help me? attached are sample files and settings
  • Mar 20, 2023 5:35 PM UTC
  • 184 views
gis.analyst
Forum|alt.badge.img+4
I used several models. once without transformers and once with EsriReprojector, reprojector, and ...In all cases, the results are not in correct projection.
even I force to create prj file and it has the correct projection but output dwg has UTM projection with wrong coordinates
Best answer by daveatsafe
Hi @gis.analyst​,
In the Advanced Parameter for your AutoCAD reader, please set Ignore User Coordinate System to Yes. This will place your source data in the correct location.
daveatsafe
Forum|alt.badge.img+24
  • Mar 20, 2023 10:35 PM UTC
Hi @gis.analyst​,
gis.analyst
  • Mar 22, 2023 12:56 PM UTC
Thanks a lot. It works
