Hi! I want to add 3D to a 2D polyline wherever it intersects with a 3D contour line
  • Sep 2, 2019 5:30 PM UTC
  • 5 replies
  • 84 views
...and then also interpolate Z for every vetex. thanks! /Erik
itay
Forum|alt.badge.img+19
  • Sep 2, 2019 6:23 PM UTC
Have you tried relating the lines and see if the Z value can be transferred to the 2D feature?
Forum|alt.badge.img+54
  • Sep 3, 2019 9:53 AM UTC
A surface draper should work here, might need some additional work to handle the z values at the start and end points if they don't intersect a line
jonas_nelson
Forum|alt.badge.img+34
Interesting. Can the SpatialRelator use the z-value from the 3D line and transfer that as a z-coordinate for a specific (=intersecting) vertex, and not just transferred as an attribute (or a z-value) for the whole 2D line object?)
Forum|alt.badge.img+63
Just throwing an idea out there: the SurfaceDraper
nielsgerrits
Forum|alt.badge.img+67
This is a lot easier indeed!
