Hi, I'm using LineonLine overlayer to try and create points where there is an intersection. I'm getting 1440 points in my result, but when I open the file, it's empty? Can anyone suggest any help? Thanks
  • Apr 1, 2019 12:24 AM UTC
  • 56 views
I'm using Tester after LoLoverlayer, is there another step ie. Vertex Creator? There's coordinates when I look at it in Inspector, but no coordinate attributes in writer. I've made sure all coordinates are set to MGA94-56. I'm manually copying atrributes from Tester transformer, as I still have 56000 results from LoLoverlayer before passing through the Tester?
Thanks
@1spatial
danilo_fme
Forum|alt.badge.img+58
  • Apr 1, 2019 2:08 AM UTC
Hi @fional
Did you to use the transformer Intersection?
Thanks
  • Apr 1, 2019 4:01 AM UTC
I have tried both the Intersector and Topology Builder transformers but didn't get any results. The main issue here is that I am getting 1440 results in the writer, plus I get a map and table in Inspector, but the writer file is empty when I open it in MI. I've never had an empty writer file when I've checked in Inspector first and see a map and a table.
gio
Forum|alt.badge.img+15
  • Apr 1, 2019 8:35 AM UTC
@fional
What format are you writing to and how?
Have a pic or sample of the process?
