hi, how can I read a tab deliminted txt file and convert to a table?
erik_jan
Forum|alt.badge.img+21
  • July 22, 2016
Use the Text Reader.
Then split the text_line_data attribute using the AttributeSplitter (delimiter tab: \\t) adding the values to a list.
Use the ListExploder to create features per list element.
Write the features to a table.
See attached images:
  • July 22, 2016
Hi @myme, you can use the CSV reader with setting 'tab' to the 'Separator Character' parameter.
taojunabc
Participant
  • Participant
  • July 23, 2016
Oh, This is a good way.
