Hi all, How to replace band values (0-28) with textual values from the mapping attribute {"0": "Value1", "1": "Value2", ... "28": "Value29"} in a GEOTIFF raster file?
  • Jan 21, 2021 9:54 AM UTC
  • 75 views
egge
Forum|alt.badge.img+14
 I have opened the GEOTIFF file in Data Inspector (see screen capture below) and I do see the mapping attribute, containing a list with all the values.
So, I somehow 1) need to read out these values from the mapping attibute and 2) replace the band values with the textual value.
Sure FME can do this, but I did not yet figure out how... 😃
Any help will be appriciated.
TIA,
Egge-Jan
Untitled
@egge​ What's the output that you want? Most raster formats do not handle a string value. FME can add a string to a raster but in most cases wouldn't have anywhere for it go...
egge
  • Jan 21, 2021 8:30 PM UTC
Hi @Mark Stoakes​ ,
Tnx for your swift reply. Yes, I can explain where I want to go. I want to visualize the raster with a clear legend, more or less like shown in the screen capture below.
To accomplish this - using QGIS - I applied symbology to the the raster, but then the legend showed values 0 to 28 and I had to - manually!! - replace these with the 28 values. (Did not find a way to read out the values in the mapping... :-( )
So, I want to 1) recolor the raster and 2) assign the textual values to the cells. I guess it should be done somewhere between the Extract and Load steps, in the Transform phase of the process, right?
Capture
Hi @Mark Stoakes​ ,
Capture
@egge​ this looks like something you have to do in QGIS. FME can easily use a lookup table (DatabaseJoiner), but I don't think you can save those values in the raster. It seems to me that it's QGIS that needs to be able to read the lookup table for the legend.
