Hey community, I cannot read in a right way the ITF Switzerland ASCII format file because I need to attach the .ili format file together, How can I do it in a right way? Check the message
  • Aug 2, 2022 6:29 AM UTC
  • 34 views
giuseppecfgeo
Forum|alt.badge.img+5
WhatsApp Image 2022-08-01 at 23.06.53
danminneyatsaf
Forum|alt.badge.img+13
Hi @giuseppecfgeo​ what Reader are you using to try and read in the dataset?
For reading the .ili file I suggest taking a look into the SWISS Interlis Reader. I'm not too familiar with the format myself, but if you are able to share the .ili file and the log file from your workspace with us, some users might be able to provide you some better tips on how to get the Reader working correctly.
