Help with syntax when using Tester transformer
  • Nov 28, 2023 7:25 PM UTC
  • 5 replies
  • 147 views
aaronm2800
Hi, I need some help setting a basic test with the tester transformer. I'm trying to fail rows from a feature if they match any values in a csv file I've added as a reader. I'm having some issues getting things configured correctly.
So something like NOT @Value(field) Contains <Right value>. But I can't seem to connect the right value. Connecting the csv as an input isn't what I want, but I cant figure out the syntax to use in conjunction with '$(SourceDataset_CSV2)'.
Sorry for this basic question but I couldn't figure this out looking at the documentation. Thank you.
Best answer by hkingsbury
A tester only works at the feature level, so you can't look at data that isn't on the feature.
One approach (the simplest for me to explain and not a particularly efficient solution) is to read your CSV file in as a text file and make sure you're reading the whole file at once (so it comes on one feature)image
Then pass this to a featuremerger as the supplier and pass your other data to the requestor port. In the feature merger set the join to '1=1'imageComing out of the merged port, you should now have the same number of features coming in your requestor port with an additional attribute containing the entire csv.
Now you can pass this into the test with your original contains statement with the right value now being the attribute containing the csv file
hkingsbury
Forum|alt.badge.img+73
  • Nov 28, 2023 7:33 PM UTC
aaronm2800
  • Nov 28, 2023 9:37 PM UTC
Thank you for the idea. Just to clarify, would this add the entire csv as an attribute column for each row?
hkingsbury
  • Nov 28, 2023 10:05 PM UTC
As its being read in as a text file (not as a csv) it treats each row as a new feature (doesn't split it into columns), then, because the reader is specified to read the whole file at once, it actually reads the complete CSV file into one attribute, on one feature. It's then treated as a text field
aaronm2800
  • Nov 29, 2023 7:37 PM UTC
Thanks again, it does seem strange to me there isn't a more efficient way to do something equivalent to 'if x in y: <action>'.
hkingsbury
  • Nov 29, 2023 7:56 PM UTC
In a way, that is exactly what youre doing (if x in y) FME works at a feature level, so that statement is true for the context of a feature, hence 'loading' the whole csv into one attribute
A more 'complex' and efficient approach is to use an inlinequerier which loads your input data into an SQLite database which then allows you to write a SQL statement to do 'database level' joins etc
