Help creating an expression with StringSearcher transformer.
  • Sep 13, 2021 6:23 PM UTC
  • 131 views
Hello, I'm trying to extract a number out of my comments column. I'm not sure how to write the expression? or if I'm using the right transformer? I'm still new with FME.
The number I am trying to extract is 8 digits and is put in comment field with this format "/ 12345678 /" an example of the format is below.
VB BLVD / 59208085 / L06-514 / ATT 8547
Is there a way to extract this number?
Thank you!
Best answer by danilo_fme
Hi @egeiser​
I created your case:
String
Attached the Workspace.
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Sep 13, 2021 6:52 PM UTC
Hi @egeiser​
String
Thanks in Advance,
Danilo
  • Sep 13, 2021 8:18 PM UTC
Hi @egeiser​
String
Thanks in Advance,
Danilo
This worked! Thanks!
danilo_fme
  • Sep 13, 2021 8:33 PM UTC
Awesome! I'm happy to help you!
