Hello, I would like to vectorize a raster (.tif) to obtain a .gpkg The raster contains distance attributes that I would like to keep as an attribute in the final data. I have used a RasterCellCoercer to do this but I can't find the desired attribut
  • May 10, 2022 8:55 AM UTC
  • 41 views
Forum|alt.badge.img+63
Can you check the result with the Feature Information Panel? That's the 2nd icon from the bottom. It opens anther panel and in case of raster data tends to give a bit more information, such as the band value, which should be your distance.
