Hello! I was wondering if you can help me. I'm working on a project with drill core log data. The idea is to add the data to a GIS. With that data drill core log profiles are generated.
  • Jul 27, 2021 8:22 AM UTC
  • 114 views
I've played around in Python in an ArcGIS Pro Notebook and like to take that code into FME. Because of organizational reasons, I might not be able to import the modules I need. Is there a way to make the profiles with other transformers? or some other way in Python, maybe?
Attached is the code I use in ArcGIS and the testdata used there. Further attached is an example of the profile.
The data is organized in drill cores consisting of multiple layers, the thickness is indicated with Laagdikte [mm], the sample data has 3 drill core with 6 layers each.
Any kind of help would be greatly appreciated!
Thanks!
Linda
Best answer by debbiatsafe
Hi @lindaf​
You may want to look into the ChartGenerator. A stacked bar graph should create a raster that is similar to the profile example you shared. I have attached an example workspace to this post and I hope it helps.
debbiatsafe
Forum|alt.badge.img+24
  • Jul 28, 2021 11:59 PM UTC
Hi @lindaf​
  • Aug 24, 2021 9:19 AM UTC
Hi @lindaf​
Thank you! This works really well.
