Hello! I'm having the followin error opening a KML file in Inspector:
  • Dec 27, 2022 7:44 PM UTC
  • 39 views
Feature Type: `'
Attribute(string: UTF-8): `fme_geometry' has value `fme_point'
Attribute(string: UTF-8): `fme_type' has value `fme_point'
Coordinate System: `LL84'
Geometry Type: IFMEPoint
Coordinate Dimension: 3
(-123.07702450837,49.2953290456494,0)
Data displays well, but I wonder about the implications and causes...Does it have to do with ESRI engine?
JennaKAtSafe
Forum|alt.badge.img+9
Hi @igorrichwin​, are you using a version of FME Desktop or ESRI's Data Interoperability extension?
Seeing that your data displays well I believe it may be a warning about a certain feature type. Feel free to drop your full logfile here as well!
  • Dec 28, 2022 12:16 AM UTC
Hi Jenna,
Your answer is much appreciated. I'm using ESris's Data Interoperability. The thing is I'm trying to execute the exercises provided by your online trainings using the very same data, but I always get stuck with reprojection errors. If you could kindly take a look at this log and point me to a solution :). Here is a print of the workflow. Many thanks
