Hello, I'm experiencing an issue with Excel. My goal is to efficiently transfer all the data from the table into an Excel spreadsheet.
  • Oct 25, 2023 8:16 AM UTC
  • 94 views
Forum|alt.badge.img+63
So what's the issue exactly?
bmwhbmwh
Forum|alt.badge.img+4
  • Oct 25, 2023 11:30 AM UTC
the excell only contains the autocad alignment but not the numbers below
panda
Forum|alt.badge.img+20
  • Oct 25, 2023 6:00 PM UTC
You can try set these 3 things.
1) In Excel Writer, On User Attribute Tab > Attribute Definition instead of selecting Dynamic have you try change it to Automatic?
2) Make sure that Destination Microsoft Excel File is located where you can get to it.
3) In Excel Writiner, Parameter > Start Position leave those field empty (if it's brand new excel file)
If these still not working, please provide some test data, excel template (if there's specific excel style you need it to be in), or you can provide the setting you currently using on the excel writer.
bmwhbmwh
  • Oct 30, 2023 7:56 AM UTC
It worked. thank you very much. 😁
