handle XML and their elements
gpt_geoinfo
Forum|alt.badge.img+3
Hi community,
although I'm not new to FME I am quite inexperienced in FME+XML and I would be happy if someone could help me.
I already watched the corresponding webinars and read the manuals, but unfortunately I can't get the problem solved.
Input-XML:
The XML is quite complex. I made a screenshot and hope you can read it. The main section is <SymbolInstance> with <SimpleSymbolDefinition> and <ParameterOverrides> in it. There you can find the variable "COLORBYLAYER0" in the Path-section which is referenced (indicated by %). The concrete value can be found in <ParameterOverrides>.<Override>.<ParameterIdentifier> resp. <ParameterValue>.
Output:
My aim is to replace the variable with its value.
Is that an issue I can handle with FME?
Thanks in advance,
Maria
fmelizard
Forum|alt.badge.img+22
Hi Maria,
This is a typical case for the XMLUpdater where a value can be replaced/deleted/renamed etc.
gpt_geoinfo
  • July 16, 2013
Hi Itay,
thanks for the keyword. XMLUpdater seems to meet my needs.
But when I'm trying to replace an element's content it fails. I already tried with a simple XML:
Input:
<data>
    <root>
        <element>HeyYou</element>
    </root>
</data>
XMLUpdater:
Update Type: Replace Contents
XML Path: /data/root/element
Value Type: Plain Text
Value: HelloWorld
Output:
unchanged Input.
What am I doing wrong here?
When I use an XML Path of /data/root the output is
<data>
    <root>HelloWorld</root>
</data>
fmelizard
Hi Maria,
The XML updater can be a bit confusing to use.
I have uploaded a demo ws that demonstrates how to replce tags (based on your example)
Hi Maria,
I tested the XMLUpdater with your "Hallo World" document, I confirmed that it works expectedly.  As an additional information: although the XMLUpdater is a good solution, the XQueryUpdater transformer also can be used, and might be more flexible if the XML document can have multiple "SymbolInstance" elements with different parameter override definitions.
Takashi
gpt_geoinfo
  • July 24, 2013
Hi there,
I found the bug: FME 2012. In version 2013 everything runs as expected. Actually I didn't want to install the latest version, but there's no getting around it.
Now my next question:
How to replace the element-contents with their belonging value?
A simple example:
<data>
    <root>
        <element>%abc%</element>
        <element>%xyz%</element>
    </root>
    <leave>
        <param>abc</param>
        <value>HelloWorld</value>
    </leave>
    <leave>
        <param>xyz</param>
        <value>HelloFME</value>
    </leave>
</data>
The result should be:
<data>
    <root>
        <element>HelloWorld</element>
        <element>HelloFME</element>
    </root>
    <leave>
        <param>abc</param>
    </leave>
    <leave>
        <param>xyz</param>
    </leave>
</data>
When using XMLUpdater with the XML-Path "/data/root/element" and the XQuery "data(/data/leave/value)" I receive
<data>
    <root>
        <element>HelloWorld HelloFME</element>
    </root>
    <leave>
        <param>abc</param>
    </leave>
    <leave>
        <param>xyz</param>
    </leave>
</data>
Can you give me some hints? I'm quite new to XQuery and just need some hints to manage it.
-Maria
Hi Maria,
  I'm not sure whether the XMLUpdater can be used in such a case, but, for example,  the XQueryUpdater with the following XQuery expression would work:   -----   for $elem in //element   let $param := fn:replace($elem, "^%(.+)%$", "$1"),     $value := for $lv in //leave where $lv/param = $param return $lv/value   return replace value of node $elem with $value   -----       ... it's not easy to explain this expression, sorry. Try this first, then see these sites:   XQuery 1.0: An XML Query Language XQuery 1.0 and XPath 2.0 Functions and Operators
Takashi
[2017-05-01 Update] XMLXQueryUpdater with this expression may be more elegant.
for $x in //root/element
let $p := fn:replace($x/text(), '^%(.*)%$', '$1')
return replace value of node $x with //leave[param = $p]/value
or
return replace value of node $x with //leave['%'||param||'%' = $x]/value
P.S. If you need to continue discussion about this subject, please post a new question having a link to this thread. Maybe there are XQuery / XPath experts in the Community, but they perhaps don't check old questions.
gpt_geoinfo
  • July 25, 2013
Hi Takashi,
thanks a lot for your response!
It helps me so much. Indeed I found XQueryUpdater and a solution as well, but mine has 3 times more lines.
Now I can go on.
Thanks again!
-Maria
gpt_geoinfo
  • August 12, 2013
XMLUpdater is exactly what I need, but unfortunatly it doesn't work fine in version 2012. So I upgraded to 2013. Everything works now.
Thanks for all your help!
lau
  • March 14, 2016
I hope you found the solution :) For those who are interested, you can use [] to access to the different elements of your XML.
