Grouping attribute range from one field to another.
  • Oct 15, 2018 6:35 PM UTC
  • 47 views
Hi
I want to do something like this in FME
Original Table
AgeNumber0-10510-201020-30230 plus4
Create new attribute with range values or group values in Name field by ranges.
NameNumberRange0-1050-2010-20100-2020-30220 plus30 plus420 plus
The only way I can think of is to use Attribute Creator and use conditions to set up each category range. I am hoping there is an easier way of doing this.
Andrew
fmelizard
Forum|alt.badge.img+22
  • Oct 15, 2018 8:04 PM UTC
Hi @andrewy You've got ranges already, so I'd recommend the AttributeValueMapper. Use the Import wizard if you've got a long list to bring into it.
