Group by Address and create min max attributes
  • July 22, 2016
  • 163 views
I'm hoping someone could help me figure out the best way to group a dataset by address and create min/max attributes to use later in the workspace.
I have multiples of same address(es) with policy effective and expiration dates
I've used aggregator to successfully group and create a count (so I know how many of same address are in the dataset)
What I want to do also is create a min effective date and max expiration date for each address and somehow calculate the time between these dates or at least determine if it is >3 years.
Appreciate any pointers :)
Best answer by todd_davis
example.zip
Instead of using the aggegator, how about pass it to the statisticscalculator. You need to make sure your date is in an appropriate Date format (YYYYMMDD). In stats calc, set you grouping to what you had in the aggregator. Analyze the date field. You can then get min, max and count of the dates. Then you can use datedifferencecalculator to get the difference....Example attached
Otherwise you cold create lists in the aggregator and listsorter them. Use the list indexer to create attribute in for high and low date, and then datedifferencecalulator to get the difference.
todd_davis
Forum|alt.badge.img+23
  • July 22, 2016
example.zip
  • July 22, 2016
example.zip
Thanks Todd, I will try the statisticscalculator, it sounds like that will do it. I formatted the dates and tried the list route with aggregator, created concatenated list for the dates and then split and used the ListRangeExtractor to get min and max. Complicated way to do it but worked! I will try statscalc to see if that will simplify it a bit. Thanks for your help.
