Greyed numbers between transformers
  • Jul 16, 2020 8:53 PM UTC
  • 58 views
If anyone knows, I was wondering why I have some greyed out numbers between the transformers, and then it comes back to black when writing the data?
fmelizard
Forum|alt.badge.img+22
  • Jul 16, 2020 10:43 PM UTC
Hi @yannick Did you select the feature type and Inspector and then "Run To Selected"? From your screenshot it appears that only the end of your workspace was last run, but the greyed-out numbers indicate what was run previously.
  • Jul 17, 2020 7:38 AM UTC
It's related to the feature caching, as alluded to by @danatsafe. Black numbers indicate features that were processed in the current run, grey numbers indicate features processed and cached in a previous run.
  • Jul 17, 2020 12:08 PM UTC
Thank you!
  • Jul 17, 2020 12:09 PM UTC
Thank you!
