GML : FME caanot read coordinate system
  • Feb 27, 2025 11:19 AM UTC
  • 63 views
lgrie
Forum|alt.badge.img+8
Hello,
I am currently running into issues when reading a gml file.
I have two files, build exactly the same way.It reads perfectly well the coordinate system from one file, but not from the other.
File 1
File 2
It seams to me that the the connection is not beeing read perfectly.
cables is a table “CableElectrique” whereas “my” is the geometry
I am sorry, I cannot provide more than snippets :(
kailinatsafe
Forum|alt.badge.img+24
Hello ​@lgrie, thanks for posting! Apologies, do both files have different coordinate systems, or does only one have a coordinate system? May you re-iterate the difference between the source gml files?
Also, are there any warnings or errors in the logfile on read, specifically relating to geometry?
Within the GML Reader > GML SRS / Geometry Parameters > there is a "Process Xlink Geometries" parameter which is set to ‘No’ by default. Can you set this to ‘Yes’ and try reading the file again? If this does not resolve the issue, I might suggest you submit a support case with us so we can take a closer look. Happy to help, Kailin.
