gltf reader error
  • Feb 6, 2026 2:58 PM UTC
  • 65 views
charry
Forum|alt.badge.img+5
XML Parser error: 'unable to open primary document entity 'C:\FME_TEMP\wbrun_1770387492402_18548\fmetmp_13\1770389629687_17428_d\importedModel390.dae''
An error has occurred. Check the logfile above for details
The below feature caused the translation to be terminated
glTFReader_FeatureReader_3_<Rejected> (TeeFactory): glTFReader_FeatureReader_3_<Rejected>: Termination Message: 'glTFReader_FeatureReader_3 output a <Rejected> feature.  To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
evieatsafe
Forum|alt.badge.img+28
  • Feb 9, 2026 10:43 PM UTC
Hi ​@charry I believe you are missing some information in this post so I’ll ask some follow up questions:
  • Are you using the format reader or the FeatureReader? Does this change the error message?
  • What parameters are you using in the reader?
  • How is the gltf file being created?
  • Are you able to share the full translation log file?
  • What version of FME are you using?
  • Could you share a sample file we can use to reproduce the error?
