GIS to CAD - Annotations too big
  • Mar 2, 2020 9:25 PM UTC
  • 79 views
philippeb
Forum|alt.badge.img+23
Hi there,
Using FME 2019.1, trying to convert GIS annotations (ArcSDE) to DWG.
This is an example of my data source in ArcGIS.
This is the final result in AutoCAD. Why am I getting those big disproportionate ugly annotations?
Is there anything I can do? TX
deanhowell
Forum|alt.badge.img+24
  • Mar 2, 2020 10:48 PM UTC
Part of the issue could be the font being used in the CAD drawing is not the same as the GIS.
There is an autoCAD attribute called 'autocad_font_typeface' which you could set to the same font used in the GIS file before you output top DWG.
There is a post which may also help https://knowledge.safe.com/questions/105764/is-there-a-way-to-control-the-size-of-labels-withi.html which discussed the AutoCAD text size.
Hope that helps :)
