Getting the match_id in the "Matcher" transformer to start counting at a specified number
fmenco
Forum|alt.badge.img+5
I have two datasets of line features which I want to check individually for duplicate line features. However, the output containing the duplicate line features of both datasets should be combined in one dataset. I used a Matcher transformer on each dataset. When combining the output I of course get similar match_ids for features, that aren't always matches of each other. How do I adapt my workbench to avoid this?
Is there a way to set the match_id attribute of one of the Matcher transformers to start counting at a specified number?
I also can't send both datasets to the same transformer, because for my datasets that would result in unwanted matches.
a simplied version of the workbench
And a simplified version of the generated output
Best answer by david_r
How about adding an ExpressionEvaluator after one of the Matchers and add a large number, such as e.g. one million, to the _match_id. That way you'll end up with two separate number series, one for each Matcher.
  • December 10, 2018
Forum|alt.badge.img+31
  • December 10, 2018
If you don't want to match between datasets, you could just use the fme_feature_type/fme_basename (depending on input format) as one of the match attributes
Forum|alt.badge.img+22
  • December 10, 2018
As @egomm suggested, I think you can accomplish that by sending all features from the two source feature types into a single Matcher and setting "fme_feature_type" or "fme_basename" to the Selected Attributes parameter.
However, if you have to use two Matchers for each feature type separately for some reason, a possible way is: calculate the maximum match_id on one feature type, merge it to every feature from another feature type, and add (the max value + 1) to their match_id. The workflow would look like this.
fmenco
  • December 12, 2018
Hi all, thanks ! I applied david_r's approach, and the output firts what I want. I'm also going to try the other approaches.
