Getting start/end points from polylines
  • October 16, 2013
  • 7 replies
  • 1156 views
I need get the orientation of a line, is that possible? The type of source file is DGN, anybody has idea?
  • October 16, 2013
I'll like to get  the start point and the end point
  • October 16, 2013
You can use the CoordinateExtractor transformer to retrieve coordinates (x, y, z) of a vertex at specified index. Index 0 indicates start, -1 indicates end. If you need point geometry, the 2D or 3DPointReplacer can be used to create a point based on coordinate values. Alternatively, the Snippter transformer (Snipping Mode: Vertex) can be used to snip a vertex point from the original feature.
Takashi
  • October 16, 2013
Sorry for a typo; error: Snippter --> correct: Snipper
fmelizard
Forum|alt.badge.img+18
  • October 17, 2013
Have a look at the PolylineAnalyzer from the FME store, it returns a lot of information about polylines.
Itay
  • October 17, 2013
Depending on what you mean by orientation, you could also take a look at the AzimuthCalculator from the FME Store.
To get the general orientation of a polyline, one way could be to extract the start and end coordinates (see Takashi's suggestion) and then build a single line feature from them using a 2DPpointReplacer with the first coordinate and a 2DPointAdder for the last coordinat before passing it on to the AzimuthCalculator.
If you need to change the orientation, there is the Orientor transformer.
David
  • October 17, 2013
The coordinate extractor can extract the start and end coordinates into attributes,
Then use the formula:
atan((( y_start - y_end)) / ((x_end-x_end)))-90
to calculate the heading in degrees
  • October 17, 2013
When you calculate tangent based on coordinates of start / end nodes, be aware that the formula with atan function will raise an error if x_start = x_end (divided by 0).
If there could be such a case, consider using atan2 function.
Takashi
