Getting SCHEMA_DATASET not found error
  • Jul 11, 2023 10:05 AM UTC
  • 33 views
I am upgrading from FME Desktop 2016 to 2021.2. I am facing a issue with my FME script, getting error as "SCHEMA_DATASET" not found.
I don't want to supply data set sometimes so haven't fixed it's value. In my script I have only one schema reader and it is causing issue as I see I can't give null dataset to it.
I have tried enabling "Ignore Failed Readers" to yes and "Rejected Feature Handling" to continue translation.
Any help would be appreciated
lgrie
Forum|alt.badge.img+8
  • Jul 17, 2023 10:52 AM UTC
Hello, it is a bit difficult to help not having data to test.
What kind of reader are you using ?
