Getting Measures at a point using NeighborFinder
  • Nov 1, 2018 2:37 AM UTC
  • 63 views
kimo
Forum|alt.badge.img+10
The NeighborFinder has been updated at 2018 to return measures with the near values. But does it?
It would be great if it worked as documented, and I vaguely remember using it in the Beta. I don't see any new output attributes null or otherwise. I see a lot of hacks in FME Hub for LRS_* operations, (none of them very appealing). I did find a workaround using PointOnLineOverlayer. I assume the extra parameters on NeighborFinder were meant to do the same without an overlay.
Is there a way of getting a measure on a Route without chopping up the line?
gio
Forum|alt.badge.img+15
  • Nov 1, 2018 1:40 PM UTC
@kimo
The Neighborfinder does do that. You can see them in the feature information window.
You can extract these without chopping up your line by using a measureextractor (Type =whole line)
The measures are then stuffed in a list.
