Get the last Index of an Array?
How can we use AttributeCreator which receives an array of data to only pull the last index of that array?
  • April 25, 2018
Can you give us an example of what the array looks like?
erik_jan
Forum|alt.badge.img+17
  • April 25, 2018
If you are talking about lists in FME: The ListElementCounter will count the number of elements in a specified list. The highest index is the result of the ListElementCounter -1 (lists start at 0).
  • April 25, 2018
If it's an attribute list, you can use the following functions in an AttributeCreator.
To get the last index of _list{}:
@Evaluate(@NumElements(_list{})-1)
To get the last value of _list{}:
@Value(_list{@Evaluate(@NumElements(_list{})-1)})
  • April 25, 2018
Finally, you can use a ListIndexer with index set to -1 (=last element).
  • April 25, 2018
Here's an example of what the array looks like:
200 results contain 213 attributes of this array. I would like to get the last index of each of those arrays/nested arrays. For example, if d:ArrayOfanyType{1}.anyType{11} is the last array for d:ArrayOfanyType{1}, I want to get its value.
I hope this is clear, let me know if you need more clarification.
tim_wood
Forum|alt.badge.img+8
  • June 22, 2018
NumElements is the key - thanks for posting that answer.  I was getting frustrated that FME refused to accept }.  I still think it should be allowed, and/or you should be able to specify _list{-1} to get the last element in the list as per ListIndexer.
tim_wood
  • June 22, 2018
Posted an idea to allow use of negative numbers to get list elements from the end of list e.g. _list{-3}:
https://knowledge.safe.com/idea/72944/use-negative-numbers-to-get-list-element-from-end.html
