Get only modified attribute values
  • Feb 6, 2013 7:28 AM UTC
  • 40 views
I'm using ChangeDetector transformers and Tester transformers to compare two database tables and get modified records .now i need to get only those attribute values which have changed and not the entire record. Please help
thanks in advance
Best answer by sigtill
Have you looked at Matcher and if this Transformer can help you?
sigtill
Forum|alt.badge.img+25
  • Feb 6, 2013 9:45 AM UTC
