Get distance between multipoints within a feature in meters. Attached is file with testdata.
  • September 14, 2021
  • 5 replies
  • 4 views
mikamattila
Best answer by geomancer
Like @f.kemminje​ says, use Deaggregator and LineBuilder (group by attribute externid). But as your data is in a geographic coordinate system, use GeographicLengthCalculator instead of LengthCalculator.
Some of the multipoints contain identical points, so look into the setting of the LineBuilder to Remove Duplicate Points.
mikamatilla_Data
geomancer
Forum|alt.badge.img+51
Convert your multipoints into lines, then use the GeographicLengthCalculator (from FME Hub) to calculate the distance in meters.
f.kemminje
Forum|alt.badge.img+11
Counter​
De aggregate it
Line joiner ​group based
Length calculator
Feature merger if you ​want
bring back original points
Use counter attribute​
geomancer
  • September 15, 2021
mikamatilla_Data
mikamattila
mikamatilla_Data
Hello,
Thank you it worked perfectly! :)
geomancer
mikamatilla_Data
Good to hear, glad to be of help!
