Get bounding box Zoom level to fetch static MAP
  • Jul 14, 2020 7:13 PM UTC
  • 210 views
boubcher
Forum|alt.badge.img+11
Hello There
we are using Google static MAp Api in order to fetch static MAP for the line
since the api take the center point we thought we should use the bounding Box, get the center from there, but we are missing the zome level that should cover the entire line
https://maps.googleapis.com/maps/api/staticmap?center=40.714728,-73.998672&zoom=12&size=400x400&key=YOUR_API_KEY
we are using image fetcher transformer
or do you have any other way to do it
Thanks
jdh
Forum|alt.badge.img+41
  • Jul 14, 2020 7:48 PM UTC
So the pixel resolution of a given tile should be 360/256^Zoom.
If you divide the size of the static image (400 in the example) by the size of the bounding box, you should get your expected resolution, then it's just a matter of determining the closest zoom level.
This assumes your bounding box is in decimal degrees, the equation becomes a little more complicated if you are working in a metered projection.
jdh
  • Jul 14, 2020 8:25 PM UTC
If I did the math correctly (and I'm uncaffeinated for 9 days, so no promises) this equation should be:
_zoom = @log(360*@Value(_size)/(@Value(_xmax)-@Value(_xmin)))/@log(2) - 8
where _size is the output image size (400 in the example)
boubcher
  • Jul 14, 2020 9:40 PM UTC
@jdh
Thanks great
Its works
