Geotiff is placed different between FME and QGIS
  • Apr 3, 2022 8:10 AM UTC
  • 68 views
mathiku
Forum|alt.badge.img+8
The same geotiff is placed differently in QGIS (3.22) and FME (2022). QGIS is placing it correctly, or at least as intended by the publisher, and shows a cellsize of 2x2m. FME is setting the cellspacing at 0.1x0.1m.
Can somebody explain the difference in interpretation? And possibly how to fix it in FME - in general, not via georeferencer?
The original file can be accessed here: https://drive.google.com/file/d/1b9Euqly7DPwwYzEvLNqWj1JgxAGbTBqI/view?usp=sharing
/Mathias
GEOTIFF QGIS correct interpretation- 2022-04-03 10_00_56-dkpc-mm131406 - Remote Desktop ConnectionGEOTIFF misinterpretation - 2022-04-03 10_00_56-dkpc-mm131406 - Remote Desktop Connection
Best answer by hkingsbury
The world file (.tfw) that is with that image seems to be incorrect. It is specifying that the cell sizes are .1x.1. If you delete the world file and open the image it will be in the same place as it is in QGIS
hkingsbury
Forum|alt.badge.img+73
  • Apr 4, 2022 1:30 AM UTC
mathiku
  • Apr 4, 2022 9:48 AM UTC
Thank you. Can't believe I didn't check the world file.
