georeferencing PDF
  • Jan 30, 2020 12:09 PM UTC
  • 163 views
Hello,
I'm trying to georeference some non-geospatial PDF files. I have the corresponding GEOTIFF and a shape of the desired bound for each one. I need a PDF output in CMYK and a reasonable file size (that's why i'm not using GEOTIFF directly in the first place).
Here is what I have tried so far:
1) replace the boundingbox geometry of the pdf by the shape, but the pdf bondingbox get rejected
2) use raster georeferencer with known upper left coodinates, but I don't know how to find the appropriate cell spacing, and using raster is part of my problem (as explained above).
Any ideas ? Thanks
itsmatt
Forum|alt.badge.img+48
  • Jan 30, 2020 12:39 PM UTC
The cell spacing should be used from the raster data itself - check in the data inspector for the cell spacing. If you are worried thay the file will be too big you can use a RasterResampler to reduce the resolution of the original.
As a side not the Geotiff writer has the ability to compress if you want to use the GeoTIff. You can use JPEG compression and set it fairly high - I think 75% is the default.
  • Jan 30, 2020 1:53 PM UTC
Hi, thank you for your response, i used the raster propertyextractor on my geotiff but the cell spacing is way too small and somehow fme upper_left_x and upper_left_y aren't exactly the same as indicated in the .tfw file
Forum|alt.badge.img+63
In the TFW the upper left x and y coordinates are for the center of the upper left pixel, so they can be off from the bounds extracted earlier.
