GeometryPropertySetter - make it dynamic
  • Apr 13, 2021 7:59 AM UTC
  • 103 views
sigtill
Forum|alt.badge.img+25
Using the GeometryPropertySetter to set Traits to IFC files needs to use an AttributeExposer to be able to select the right attributes to put on the trait. This does not work well on Dynamic Workspaces with 20-100 attributes.
Is there a way to use the GeometryPropertySetter in a dynamic way? For instance submit a list of attribute names or some other "hack" to make this dynamic for "more IFC-files"?
Best answer by sigtill
Or perhaps the TraitMerger. Will look into that.
TraitMerger worked like a charm!
  • Apr 13, 2021 9:01 AM UTC
The "obvious" solution is probably to use Python, where you can programatically access any attribute regardless of if it's been exposed or not?
https://docs.safe.com/fme/html/fmepython/api/fmeobjects/geometry/_surfaces/fmeobjects.FMEFace.setTrait.html#fmeobjects.FMEFace.setTrait
sigtill
  • Apr 13, 2021 10:13 AM UTC
sigtill
  • Apr 13, 2021 10:21 AM UTC
